Having spent the last 3 months in south Australia drooling over the Toyota V8 crew cab EWT's, it's punishment time. My kZJ78 is not charging, the battery was flat, now charged up, the auto gear lever lock is only releasing manually and there are no charge warning lights on the dash at startup. The engine starts ok and all the other stuff works too. The alternator was fine on the test bed but is now being overhauled as the brushes were low. Could it be the ECU again.....
I hope there is an answer out there on the forum. Cheers Rob
