soulkeeper1357
- May 18, 2013
Hi,
I have a KZJ78 LC Prado with 1KZ-TE engine. The problem comes when after running a few hundred meters the over drive indicator lamp starts to blink even it is supposedly to be off when overdrive is turned "ON". When I switch off the O/D the indicator lamp stays lit which is normal.
The ATF level is in normal volume as I checked.
Pls help me on this
Pls help me on this
