MisterCruiser
- May 28, 2014
After doing a bit of fuel line work on my cruiser, when I was finished I went to pump the hand primer on top of the filter to prime it and I noticed a little bit of fuel leaking at the area in my attached pic.
Now, the cruiser started fine and is running fine so there doesn't seem to be air getting in or anything, is this normal to leak there or do I need a to put this on the future maintenance list. It mustn't be too bad if not affecting starting or running? ie: no air bleeding problems
Also, can someone tell me how I know if my version has the heater or no heater?
Genuine Toyota Fuel Filter Primer Head - Without Heater - [Leaving Land Cruiser Club]
