Pretty simply job tbh just a real pain in the Ass to get it out and back on with the bolts being awkward to work with...
Yep. These are the kind of jobs that infuriate me. The actual "unbolt this old thing and bolt on this new thing" process would take about 15 minutes if you had the 'thing' in question on a bench in front of you. But ends up taking several days [and several years off your life] because everything is crusted to feck and seems deliberately arranged to be as inaccessible as possible.
Interesting insides to the LSV, I think I see how it works, though I can't see exactly where the input fluid enters the chamber. I guess its in the shadow towards the top of the picture.
It does. But it's hard to see. I took a couple more snaps today:
The input port and bleed nipple are one straight run through. bit hard to see in the shadows, so I stuck a piece of wire through
The black surround of the piston is actually in two pieces [three if you count the wee plastic ring which fell out and allowed me to move the two halves this far apart]. The outer [right on photo] section is metal and fixed to the central red metal core. The inner [left on photo] section is plastic and freely rotates round the core
I was surprised how little space there seemed to be around the piston to allow fluid past it to the rear brake pipe port. However, the metal on the inner end of the core is bevelled in this one spot [the rest is round in profile]. So I'm presuming that has something to do with allowing brake fluid through. The gash in the black plastic is 'stuzbot angle-grinder' not OEM!
I never understood why the '90' needed an LSV AND ABS !
My 90 has no ABS, but it does have an LSV. The LSV is perhaps a hangover from the days before ABS was added.
They serve different purposes. The LSV alters the distribution of hydraulic pressure between front and rear brakes, depending on how much weight is over the rear axle. I'm presuming more common in vans than 'normal' cars, as I've had them on all the vans I've owned before, none of which has had ABS. ABS does what it says on the tin. Stops you skidding if you brake too hard and lock a wheel up.
I should go and dig the 90 out of the weeds where its been rusting for three years and have a look underneath...
Does this suggest you have an abandoned 90, rotting away in a corner of your garden? If so, I know someone might be interested in some parts off you. [nudge! nudge! wink! wink!]
Hopefully that is one more problem ticked off your list
So what's the next bit of entertainment ? . . . . .
That bugger wasn't even on the list in the first place. Trust me to cop for the
'Buy 2 Problems, Get 1 Extra Free' special offer!
Returning to our scheduled entertainment; It'll be either a new cambelt or coolant and tranny flush --depending on how the mood takes me. At least, from what I've seen on the intarwebs, the cambelt change looks to be one of the easiest around [I just hope I haven't tempted fate by saying that!]. I still wake up screaming some nights, remembering the ordeal of changing the timing belt on the old VW LT series. Suffice to say, you end up with more parts taken off the van to get at the damned thing than are left attached.
Of course, now I've crawled under the back end for the past couple of weeks, I'm itching to get wire brushing, sanding, rust-proofing and painting that rear axle and chassis area. To preserve it in its current condition while I ponder on patching that piece of rot and any others I find. As well as deciding whether or not this LC is worth keeping. Amazing how so many of these 90s are almost mint at the front and rot boxes at the back. It's like the world's most misguided cut'n'shut operation.
