BobMurphy
- Mar 1, 2010
Ah the joys of buying a 13-year-old truck .
A week or two after I bought it I noticed a few spots on the tarmac. This developed during the next few weeks into a constant drip which only stopped when the tank was down to one quarter full (or, with my luck, three quarters empty).
On the '95' the tank is slung from the underside of the body and the guard is bolted to the chassis - the two never meet and the guard can be removed in order to inspect the tank.
The 100-Series is different, the tank sits in the guard on a couple of rubber strips and the pair are then slung from the body.
The only way to inspect the tank is to remove it .
First I had to drop the exhaust in order to get at the bolt that holds the rear strap. I would have liked to remove the rear two sections completely but they are plugged together and it will take more than my efforts to separate them (as I want to re-use them). I therefore had to work with the main silencer box in the way.
True to form, most of the bolts underneath are rusted solid and I didn't want to go near the tank with a gas torch . I ended-up cutting the rear strap after putting a transmission jack under the tank.
I won't go into all the problems but by 18:30 this evening I had managed to get the tank out:
It is very thin around the seam and the top. Some of the fittings are crumbling away.
I was hoping to save the guard as, according to Simon Holton, a new one is £306.41 and is on back-order until 4th September 2014 .
Unfortunately it is toast. It looked reasonable until I let it fall flat on the ground whereupon it fell apart. I'll now start searching the Breaker Yards.
So, I am now waiting for a delivery from Simon. A new tank, straps & fittings that are available now come to around £900. At least I won't have to worry about a leaking tank again .
Now to tackle those seized bolts with a gas torch while the tank is out. I'll attempt to replace all rusted bolts with stainless with anti-sieze paste while I await the delivery.
Shame really, as the truck looks very nice on top .
The things I do for daughters with horses . . .
Bob.
Bob.
