This is my little project a toyota land cruiser 70 that I am completely renovating and rebuilding.
I have escaped the war in Ukraine in a few minutes and today live a wonderful life in Sweden, but I am absolutely sure that I want a fully packed car that is forever ready to escape if something else happens in the world.
Normally I work as an IT engineer but as you can see I try to learn to build a car in my spare time I spend about 2-3 hours every day building my car
Hi, I'm from Ukraine and have fled the war there and now live more in Sweden. Today I have a toyota hilux as a utility car and I build on my adventure bug out car every day and it is a Toyota land cruiser 70 with portal axles 40 inch tires mm mm mm
-The axles are Toyota's large diff blocks with latches and portal housings with disc brakes both front and rear.
-The engine is a BMW M57-d30 6cyl commonrail diesel
-The frame is extended 22cm to accommodate the plans to come
-The rear axle has been moved back 20 cm so that there will be another body in the back and accommodate 40 inch tires
-The front axle is moved forward about 6cm
-New wheelbase is very close to 100 inches
-Warn winch with synthetic rope and 12000lbs
-ARB Compressor
- 40 13.5 17 tires on 17x9 et-6 rims (New tires not mounted on rims in pictures only 35")
+So much more
The plans are many and a lot will be built according to my plans and from what I can see, my car seems to be a bit unique as I have bits of everything in mine but also a solution that seems to be completely my own solution.
I will have a rear end that is integrated with the driver's cab that can be used overnight when folded out, but at the same time the car will be able to be used as a pickup when it is folded
I will give some updates from time to time
-ARB Compressor
+So much more
