- Jul 1, 2013
Doing a bit of research and it looks.like the ctek d250s is perfect for lifepo4's that have a BMS built in. It will flood at 14.4v/20A and the BMS will basically shut off before the ctek gets to it's float.
Disable the temp control, add a smartpass, and it's all the charging bits needed. Solar+alternator, starter pair and a lifepo4.
So what am I missing, why are people spending a ton of money buying super specialised lifepo4 charge controllers? Is that to compensate for a lack of BMS ?
