Roger Fairclough
- Dec 14, 2010
That's the supplement Ben. You may well need the basic electrical manual, ref.EWD168F dated Aug., 1992
Roger
Roger
Rob said:Just called them and it will be about £70 including delivery for 2 lights: WT-J7L and WT-J7P.
Roger Fairclough said:That's the supplement Ben. You may well need the basic electrical manual, ref.EWD168F dated Aug., 1992
Roger
Roger Fairclough said:Rob said:Just called them and it will be about £70 including delivery for 2 lights: WT-J7L and WT-J7P.
I'm up for a pair of those. How do you want to play it?
Roger
ben said:thanks Roger, i will make some enquires and see if i can buy them all.
Roger Fairclough said:I sent my X-Brake back to Simon, and I have now received a refund for the unit but not the cost of the return postage.
One comment that Simon made was that Toyota owners do not seem willing to fettle the original parts to enable the X-brake to fit.
Now to Bens problems.
The degree of rubbing on the disc itself is considerable, that amount of bluing suggests the temperature was close to red heat.
On the Land-Rover and Suzuki set-ups, the X-brake replaces an existing drum brake. This means that the original brake was fixed to a machined surface so that it was at exactly 90 deg. to the output shaft c/line. On the Toyota, the X-brake back plate is bolted to a simple, non-machined, aluminium flange. This means that any variation in thickness of these mounting bosses will automatically create a situation where the mounting plate will be twisted. The amount of the twist will be directly proportional to the variation in boss thickness.
From an engineering point of view, there are a number of points that need checking to ascertain what the problem(s) is/are.
Ben.
Can you bring the motor to me in Redditch?
Roger
wobbly said:Some great work, but reading the thread gives the definite impression that there is some guinea-piggery with the system, maybe a bit more testing needed to work out the potentiasl hurdles.
At least when you have yours sorted you can give the seller a heads up on fitting issues.
Pete
Roger Fairclough said:Ben.
The complete set of manuals consist off the following:-
"Repair manual for chassis and body ref. RM183E". It's dated Jan., 1990 and covers RJ7 series, LJ7 series, FJ7 series, PZJ7 series and HZJ7 series.
Available £40.02 +VAT
Supplement to above dated August 1992 ref.RM315E. This covers RJ7 series,LJ7 series FZJ7, 80 series PZJ 7 series HZJ7, 80 series and HDJ 80 series.
Available £25.47 +VAT
Supplement to above dated May 1993 ref.RM346E.This covers RJ7 series, LJ7 series and KZJ7 series.
No longer Available. £9.40 +VAT
Engine manual for 1KZ-T dated May 1993 ref.RM353E.
No longer available. £18.77 +VAT
Electrical manual, dated August 1992 ref.EWD168F. This covers FZj7 series, HZJ7 series,PZJ7 series,LJ7 series and RJ7 series.
Available. £16.43 +VAT
Supplement to above dated May 1993 ref.EWD176F. This covers KZJ7series, LJ& series and RJ7 series.
Didnt ask, as i already have this manual
When I bought the car, some 14 years ago, I did a deal with the Toyota garage that sold it that they would supply all the manuals at cost less 50%. Toyota GB sent the wrong books, so I did a deal with them that they paid the other 50%. At the time the complete set retailed at about £150.
Roger
ModelMakerMan said:Be careful using that switch on the glow plugs for too long, they should only be activated for 15secs max at any time or you will burn them out and then only if they are 11v plugs (if they are 6v you have even less time). A momentary switch would be better.
Have a look at this
