so i left the batteries on charge over night.
fired her up this morning, all the warning lights went out on the dash, and the volt meter shot straight up.
nice healthy reading at the batteries.
the battery terminals i recently bought turned out to be complete crap!
so i took them off this evening.
they were bent, cracked in places, and wouldnt clamp around the terminals tightly.
new heavy duty terminals.
they seem a lot better.
decided to fit the new washer jets, and discovered they wont fit through the holes in the bonnet.
i read the threads/posts of people fitting them to 80's as an upgrade and stupidly presumed theyd fit a 70!
i dont fancy making the holes in my bonnet any bigger, so looks like there surplus. anyone after any?
decided to try and get the pulley off the old alternator.
the little 10mm headed bolt that locks the nut on, had rounded.
i hammered a smaller socket on, but this then just turned on the nut.
decided to drill it out!
i was then able to undo the 19mm nut with the ratchet gun.
i could then use a puller to remove the pulley.
few more bits to do on it tomorrow night, before the weekends big laning trip.
a couple of links.
firstly to the alternator ive fitted, incase anyone plans on doing the same:-
http://www.startermotor-alternator-stor ... 2297-p.asp
and secondly to an electrical place i found through ebay, but have since discovered is only just up the road from me. i got the new battery terminals from them:-
http://adesas.co.uk/product_info.php?cP ... ucts_id=38
very pleased with the service and prices from both these companies.
