so.........................needed to get the huge tyres fitted.
this first issue that needed sorting was the exhaust, as there wasnt enough clearance in the rear wheel arch.
jacked it up.
and took the wheel off.
i needed to adjust these mounts to allow the exhaust to move back as much as possible.
after unbolting the 2 sections of exhaust, i managed to adjust the rear mount enough to allow me to move the exhaust back by about 50mm.
much better.
need to cut the end off now.
i ordered this at the beginning of last week, and hoped it would be here for the weekend, but it hasnt arrived yet.
http://www.ebay.co.uk/itm/110904518443? ... 659wt_1357
but i wanted to get my tyres fitted this weekend, and wasnt going to let the fact a part hadnt arrived, get in the way of that.
i went and picked up some 2.5" clamps.
and worked out where best to cut the exhaust.
couple of minutes with a reciprocation saw later and the exhaust was cut!
ive never been very pleased with the exhaust.
the place i took it to in Brmingham didnt do a very good job.
one day im going to take it beaudesert and get them to build me a complete new system, as im fairly confident they will do a good job!
http://www.beauexhausts.com.au/
so back to my exhaust......................................................
what i did next is the biggest bodge ive ever done on this truck.
but it is only temporary until the bit ive ordered arrives.
bush mechanics anyone?
did a bit of flex testing, and it clears the exhaust and everything else.
so with the back end now sorted, i could turn my attention to the clearance issues on the front.
so out with the prayer mat and 9" grinder.
strapped the slider in place, to prevent it falling on my head.
and cut it off.
id already cut one end on an angle, to give me more clearance.
but i hadnt done the other end.
marked it.
cut the end off, and then cut a piece of 4mm steel to cap the end back off.
welded it on.
and ground down the edges.
i then repositioned the slider in places, and used blocks of wood and plastic packers to get it just right. i moved it towards the back of the truck, by about 20mm.
and tack welded it back onto the brackets.
i then unbolted it and fully welded the brackets back on.
quick lick of paint.
and re-fitted it.
much better.
just the inner arch to adjust next.
which was easily sorted with a pair of tin snips and a hammer.
so one side done i was onto the next.
needed to cut both sides on this slider.
no sooner had i come out of the workshop after cutting and welding the ends of the slider, it started raining.
i thought this is great!!! we havnt had any rain for ages.
try everyday for the past 2 or 3 weeks! meant to be the middle of summer.
damm i hate the weather in this country!
ok rant over.
wasnt going to let something like torrential rain stop me doing what i wanted to do!
so out with the big tarp.
slider positioned.
as soon as id finished welding the sun came out.
other side done.
i can only just lift the spare into the back.
if i get a puncture off road, i wont physical be able to lift the punctured wheel back in if its got an extra few kg's of mud on it.
winch rope over the roof, through the sun roof, through the back doors, and attached to the dirty heavy wheel?
so some flex testing................................
at full articulation the front wheels will catch if on full lock.
the only way to clear these 37" tyres would be to either cut a huge amount off the wings, which i dont want to do. or lift the suspension more.
ive been meaning to change the [strike:edepblxk]cheap, crap, rusty, sagging[/strike:edepblxk] ironman suspension lift anyway. so i might stick a 4" lift on it.
but i dont want to lift it anymore until its registered and on the road in OZ.
more testing.
i thought i may have to adjust the rear bump stops to stop the tyre from hitting the inner arch. but it clears perfectly.
ive got just the lane to test the new tyres on.
ive never managed to drive up it without winching.
hopefully with the aggressive, huge new tyres dropped down to 10psi, and with both ARB lockers engaged, i might now stand a chance!
