Hi all,
1987 LJ70LV- MNXW 2L-T,
that finds it hard to start when the temperature is lower (12/20 °C), but when the engine is hot the start is immediate
so I checked the entire pre-heating system and I have these results:
1 only glow plug relay ( but shouldn't they have been 2 ? ) which is ok
4 glow plugs ok
pre-heating timer (behind glove box) I could not check it as it is different from what the service manual indicates....
I also couldn't locate the glow plug resistor
can someone help me ?
thank you
Giacomo
4 glow plugs ok
thank you
Giacomo
