JonFJ1969
- Feb 6, 2013
Hi All, just bought a 1990 LJ70 that had been stood for a while, seemed to of had been running on the dregs of what was left in the bottom of the tank, took it out for a spin and seemed to loose power and wouldn't rev, eventually got back and the fuel filter was clogged so i changed it, put about half a tank of fresh diesel in her and all seemed fine but she still seems to have no power. i did the priming of of the fuel filter after the change and she runs fine but after a while it has no power and doesn't want to idle, tried to bleed the filter again and noticed when running the priming head seems to be drawn back into the body, eventually it comes back so i am thinking it has an air lock somewhere, can some one point in right direction of what to bleed next? and how. as you can tell i am not used to working on a diesel. any help very much appreciated, cheers Jon
