- Jul 1, 2013
Now for something different. ..
ThamesWater doing some routine waterworks decided it would be fun to drill through the main waterline. 24hrs and counting of no water in the taps now. They say it should be back sometime overnight.
Got me thinking what's the best way to store water longer term to avoid / work around such situations. Not super keen on these plastic containers with stationary water. Also, plumbing in a large water tank into the house supply seems a bit 1975... mind you '75 was a great year over all.
So if we wanted to store 200 to 250ltr of water ideally to keep it usable as tap water, what are the options like? The only way to keep it fresh would be to have it be a part of an inuse tap.
Thinking of looking into these stainless steel wine making vat's and plumbing it into the washing machine. It wouldnt be too much of a hassle adding taps to it. And they are not nearly as expensive as the glass ones.
Is there a better / alternate arrangement ? If the water is restocking ( as it would f plumbed to the washing machine ) are the PE tanks ok ?
