- Mar 1, 2010
As a rule post 03 have the rear air con. Invariably the pipes running underneath the car rot out. Toyotas only solution is to replace. Other independents may be able to isolate the rear air con pipes which, if done properly, would give a more reliable set up. So I would suggest to find out whether or not you have the rear so you have a starting point.
