Measuring ride hieght.
Aspire
Hi guys.
When measuring ride height to order new shocks and springs where does one measure to on the vehicle.
And as the car is mainly used on the road and light cross country I am thinking of the peddlers set up.
Thanks in advance
Simon
Pedders have a diagram and explanation on their website but it’s usually either from top of rim or bottom of rim to bottom edge of body work
Thank you. Well I new my springs were worn . A 2 inch lift will give a ride height about 3.5 inches higher than present.
I think my 4” lift put about 7” onto the original height of mine, when i got it.
You’ll enjoy it, when done Simon :thumbup:
We're running the Pedders +2inch kit, been on for a few years now - happy to check the current ride hide, if you want to compare to what you have now?
I normally use bump stop to axle case, a little more awkward though.
Regards
