- Feb 2, 2013
I can fine tune the alignment a lot better
This is what they are aimed at Beau i can't see how they will increase how much lift you can add . I was going to get them myself as they were on amazon for a short while but never got around to it because investigation about the benefits took a while .
As far as i could work out having an adjustable upper ball joint just gives some leeway allowing for either better alignment OR better clearance between the arm and spring the problem shown in the pic Chris posted . Please note Glynn or Glen whatever his name is on the Oz forum was busting CV's while he experimented , as far as i'm aware nobody on this forum has bust a collie cv yet and heaven knows i've tried
I said earlier Coops you could run the propshaft under the chassis cross member but it would give you a daft amount of lift and you would have to rebuild the front end as in lower the diff and the arm mounts . Thats not fabrication for the faint hearted and i believe even if you did it you would end up running tyres that look far too small on a truck that tall because the bodywork would deny anything over a 35 anyway .
This is the most lifted 90 series i've ever seen and i reckon its all body lift .
