OK ladies, I would appreciate some help or clear thinking with respect to my modular steels, if someone with more brains than me would be so kind.
I have a set of four, 16"x10" and I want to get hold of a fifth. Trouble is they're non-standards and I don't want to get one with different dimensions from the other 4.
Failing that, I'd like to get my hands on a set of 5 of similar dimensions.
Here they are, I bought them new off a shelf in 2006 and I've recently had them
refurbed...
16" diameter
10" wide
Now, the complicated bit (for me) offset or backspace or whatever folks want to call it (why is it we can't all speak the same language when talking about the same thing?)
With a straightedge, I measured rim edge to centre on the outside = 168mm
I measured rim edge to centre on the inside = 104mm
Would it be correct to take the total width (rim edge to rim edge) = 278mm, divide it by 2 = 139mm and deduct this from the outer dimension of 168mm = 29mm
Would this be known as -30 offset?
What would be the backspace, 104mm?
If the above is/are incorrect would someone kindly assist me with this.
The more I read about rim dimensions, the more confused I get. It doesn't take much these days...
I just want want to know what to search for on the inter-web, either 1 or 5.
Thanks...
refurbed...
16" diameter
10" wide
Thanks...
