Following on from a few posts on Paul's thread, here's a few photos of the clamp in its new position with the latch fitted & holding the carrier closed:
Now its pulling the swing arm onto the bracket fixed to the bumper, everything is nice & secure but I do drive everywhere with one eye on it to make sure its still there!!!
I intend to fit a positive locking mechanism as well as soon as possible, probably sommat like this that I posted earlier in the thread, to prevent accidental opening.
I was think along the same sort of lines. The over centre catch I am looking at will have a built in lock and I will be able to add a pad lock if needed. I will also be mounting the wheel a little higher so I can put the number plate under it.
I chopped the big ole fixing flange off as it had been welded up by a PO & therefore the hook didn't rotate any more. Cleaned the stub left from the flange up so it slipped inside 50x50 box section & my welding buddy welded it up
