Pretty much a standard setup right now. Thanks. I will get a look.Dont know anything about your setup but if you've got a dim bulb I'd double check you have a good earth connection
Thank you. I will dig into that.Check earth point at left rear quarter panel, and under front of RH front seat. That's where the relays in the control unit, and the RDL detect.switch take their earth from.
Both the CDL and RDL lights get +12v from the same fuse, 7.5A MET.
The RDL motor gets it's earth from "Set bolt of cowl side J/B RH", which i think is the same location as the control unit/relays for the DL, behind the RHS kick panel.
But the relay coils (and the rdl indicator light) get their earth from the location mentioned above (1st line), so that's where I would start looking.
See attached diagram which is for 8.2003 to 7.2004 production of the RHD HDJ100. See 2nd page (411), bottom right corner when holding page in landscape mode.
Thank you. i'll do that tomorrow.Even if they look fine check the resistance between them and a known good earth (eg battery terminal)
Did not want to wait until morning. just been out with the multimeter and some longer wire. both earths are good.Even if they look fine check the resistance between them and a known good earth (eg battery terminal)
Thank you. i did look a them but am not sure how to read them. what you say makes sense and I can see that now on the diagram. the diagrams look lie the diagrams I make when I am building up a database in Filemaker, so hopefully I can find my way around them eventually.Yes, that sounds normal. Did you look at the schematics? The earth connection goes through a few plugs, which have to be located and tested. But, to start off, you need to measure earth connection from the actual connection point on the relays to a known good earth, and the same from the rdl detect.sw. If that is good, you have to think it over again and find another angle of attack. If bad, you have to search for those plugs, BO2, BF3, BI2, and check them. The signal from the rear detection switch also goes through BI2 and BO2.
That sounds like a fine dream.Pics of your rear plough?
Dreaming of doing up my 100 with front and rear steel bars. First pick it apart completely to get rid of rust, and then put it together with only good parts, new pipes, etc. -- If I only had a place to do it.
