So my saga continues!
Got my LC back from Mr T. after having a brand new shiny turbo fitted courtesy of my RAC insurance policy
, it was bliss not to have that constant whine that i got from the old turbo (shot bearings although it hadn't given way!)
So i drive around with a big grin on my face for a few days, after finding one day there was a pool of oil underneath my LC
, thought i had seen the last of the leaks!!!!!!
When Mr T. had done the turbo i noticed that they had not changed the oil and filter (we seem to have built up a no trust relationship!) this had been part of the warranty as specified by Turbo Technics, so i made my usual post garage call to them and they promptly invited me down to have this rectified, they were not overly concerned as the oil and filter had recently been changed on its last visit a few months ago, it was a reasonable call and my warranty was with them and not Turbo Technics but i didnt want to take any chances (especially as it wasnt costing me!)
When i took it down on Friday i mentioned about the oil leak i had got mid week, some of it appeared to be from the turbo side but most from the near side, so we cleaned it up and had a look, coming right from the top on the nearside and it seemed to be above the cylinder head base and below the rocker cover!!!
Immediate thought was the aforementioned rocker cover had failed at another point, Mr T. offered to kindly take it in and try and sort it out but me being curious decided to set to at the weekend!!!
I am sure some of you guys will have some words of wisdom along the way on this one as its my first time on manifold inlet!!!
Although the cylinder head gasket had a lot of oil on it there was also oil in the head blanking plugs, this suggested that the oil was coming from above the head gasket! a quick examination of the rocker cover had ruled that out and my last repair was holding fast
Stripped the manifold gasket off and as i did not have a spare i cleaned it all up (it seemed to be coated in some black looking Teflon coating tho9ught this was carbon deposits to start with, this was all breaking off), cleaned all the manifold and seating faces and re assembled using Hylomar to re seal.
Was a bit apprehensive of stripping this down to start with but it one of those jobs once you have done it once the next time is easy! (hoping there will not be a next time), what i really like the most is that you only need a handful of tools!
Everything went back with no problems, all torqued up to Toyota specs, i know the manifold gasket should be replaced and i might be revisiting this if my job is not sufficient but i had to know how it all fits together!
The final part was to put the coolant back in so i filled the bottle up to the brim and still had half a bucket left!, decided to take a pipe off the radiator and got most of it in, this is where i got really stuck
ran the engine and everything was fine but the heater matrix was not circulating, so i removed pipes put more water in but nothing, i could feel cold spots on the matrix pipes that suggested an air lock, this went on for some time, then it clicked! the auxiliary water pump was not actually rotating therefore the water would not circulate!
So why was the pump not circulating i hear you ask! well i had to dig for this one, i could see the clutch had not engages (it works the same way as the air con pump) so i assumed electrical? had i disturbed something?
Back to the web, someone had suggested this pump is linked to the cold start button? couldn't see the logic of cold start that increases the revs to help warm the engine up being linked to the heater matrix? any suggestions? Well it is
Turned on the cold start and the clutch engaged, cleared the airlock and heating came on as normal!
The only tricky bit was removing the last manifold nut closest to the bulkhead, very tight round the back needed the right extension bars and universal joint!
Regardless of all the pain this car has caused me i just love taking it to bits!
