hexham-scotty
- Oct 14, 2011
Hi Everyone, I hope you can help.
Recently when towing a trailer the AT overheat light came on and the O/D light started flashing.
Very occasionaly it drives perfectly normally, usually when cold, changes all gears etc.
Most of the time it skips 2nd gear (jumps 1st to 3rd) have to shift 2nd manually. O/D dosen't appear to work (or it is in O/D, not sure which) it is very sluggish due to being in the wrong gear and eventually the O/D light starts flashing).
Things I have tried so far;
Flushed the oil several times, cleaned the filter.
Removed and tested the 4 gearbox solenoids (blow through and electrically )
Checked the wire connectors above the starter (all fine)
Replaced the TPS on the fuel pump with a new one.
Gear oil is on level and clean.
I cannot read the fault codes as every where I have looked on the net says jump the centre terminal with the top right one ( in my test port the middle pin is not there ? )
The temp gauge works fine as does the speedo, I am sure the box is fine mechanically, I guess an ecu or wiring fault.
I am a competent mechanic with electrical knowledge but am completely stumped now.
Need my beloved truck for towing, please can anyone help ?
Cheers Scotty
Cheers Scotty
