I recently installed an OEM sub tank on my uk spec 80. I thought I'd post my solution to mounting the tank as Uk spec 80's don't have the necessary captive nuts pre-installed for the sub tank straps. There are holes in the right place in the body box section just above the back axle, but no captive nuts. Access here, especially on the drivers side, is very tight. I looked at using nutserts as others have done, but decided to go with opening up the holes already present to the side of where the captive nuts are, large enough to slip some captive nut plates in:
I did something similar for the rear mounting points but didn't need the little manipulation bars on those.
I make a little helper when making captive nuts plates, to make sure the nuts are centred on the hole:
