- Feb 24, 2010
So... it finally happened. With thanks to Greg and .... (I forget his name ) at Land Cruisers Overland, I now have new shocks and a slight lift on the 120.
First thoughts: I like the stance. Not stupidly high but higher than it was. I know it's higher 'cause may fat rss now gets stuck on the seat bolster when getting in.
The drive: Muct nicer than the standard setup. It certainly is harder and I am now more aware of imperfections in the road but it is not uncomfortable. Just different. The biggest difference is it is far less wallowy in bends and roads with soft, offset bumps which always caused it to lurch.
There is a local country lane I use often which always causes a grown from the RHS of the truck. After lots of checking, I concluded the noise was emanating from the wife being thrown about on the bumps. I shall attempt this again tomorrow and see. It shall be the acid test
The only thing that I was not expecting was bad understeer. When I left Greg's, I went into a circle a bit fast but then floored it while in. This would normally induce an easy drift. Today, the front just left go quite quickly and without groan from the tyres. Previously they would moan long before they got upset.
I know it's early days and the springs have to settle etc so I'll try this again in a while. I might have been a wet patch I hit...
All in all, I am happy with them and the ride, I think, is better than before.
Some pics (apologies for the angle but it was their best side )
Greg trying to convince me I need some new tyres...
