WomblingFree
- Jun 14, 2012
silvercruiser said:Just to resurrect this thread, my noise has finally reared it's ugly head.
I could here the noise at idle and it sounded like the viscous coupling on the fan, so I switched it off and thought its cold enough il take the fan off but when I started to crack the nuts to take it off I noticed movement, it is the bearing on the water pump that I changed just over a year ago so thanks to milners once again I will be taking it off to replace
So calling mr rubie![]()
Joe
Hi
Just wondering if it was your pump causing the rattle noise?
I have the same noise at turn on, disappears as soon as the engine is hot.
The wisdom down under is that its the idler wheel assembly that drives the injector pump...
