Springate’s
- Apr 23, 2020
I’m researching before buying in the Spring. Looking at a budget of upto £15K for a 150.
Trawling through various forums/FB here and in Oz has revealed the issue with piston failure. I’m struggling to assess what the possible causes are, I’ve seen the following opinions:
Injector issues
EGR blanking/delete
ECU re-flashing
Tuning chips
Long, hard towing
Poor maintenance
Weak Piston design
So quite a list!
Is this issue confined to the 150 version of the D4D or are earlier iterations also affected?
Should I be concerned or are there many 150 owners out there happily running up galactic miles?
Injector issues
EGR blanking/delete
ECU re-flashing
Tuning chips
Long, hard towing
Poor maintenance
Weak Piston design
So quite a list!
