zfsteering
- Feb 10, 2013
I have established that the motor runs by connecting a power source direct to the motor power coupling and sprays.
The problem is the power feed into the motor as there is none when the headlamp lights are on & the washer button on the wipe stalk is depressed.
The main screen washer works fine.
Can a forum member please enlighten me as to whether the headlamp washer has it's own fuse and/or relay apart from the main screen washers?
Any other power problems that anyone else has had on the washers and tips would be appreciated.
Thanks,
Stephen
Thanks,
Stephen
