- Feb 24, 2010
I have a had a 35 litre aluminium tank made for the rear of the LC and are in the process of 'plumbing it in'. Does anyone know if these (link) are 'lift' pumps? The pump is to be mounted on the bulkhead behind where the rear seats normally reside, it will be about 500mm above the tank so will need to 'lift' the water as the tank outlet is at the top.
Nothing in the ad suggests it is or isn't
