Radiator change-tips sought
mussy
So tomorrow, I am going to attempt to change the radiator on my Africa 80.
Radiator was purchased last Sunday from Roughtrax and arrived Wednesday in France!
The car is a French spec 1994 VX Auto HDJ 80 so I have a cooling radiator for the auto box.
Now I am far from being a mechanic, but have the tools and enough to to make myself dangerous with a car.
I have the Haynes manual but surprisingly search on the various forums and search have brought surprisingly little extra info.
Any tips would be great, I can't seem to get an answer if I need to drain and remove the Autobox cooler for example.
Many thanks as always,
best ,
Mussy
Remove both batteries if you have two.
Remove both battery trays(makes rad bolt access a lot easier)
remove front grill.
Remove bolts holding fan shroud, move shroud back over fan and rest there.
Disconnect the transmission cooler lines some fluid will drip out, probably a cupful?
Remove nut and bolts holding radiator, beware these may snap!
Remove bottom hose.
Remove top hose.
Lift out radiator.
I don't think I have missed anything but it is early!
regards
Dave
remove front grill.
Remove bottom hose.
Remove top hose.
Lift out radiator.
regards
Dave
Drain the coolant into a suitable receptacle?
Worth considering putting a new thermostat in whilst it's all in bits.
Good point Chris, I suggest an OE version, I had a (not so cheap) copy from Blue Print, gave me some weird temps, took out and fitted OE no issues since.
regards
Dave
