Well I am more than convinced, you Ben, or our other master-craftsman Chris, could knock a pair of them up in a mornings work.
As Good, or probably better !!!!!!!!
So there is the challenge !
Looking forward to the finished articles some time say before Lincomb?
Only joking, but looking at them, they look quite easy, compared to what I have seen you guy's and others make.
They seem to be very adjustable, maybe to much!!? Looks like you can not only adjust the blade frame angle in a couple of ways but you can also remove the blade and put it back in a lower position to give it a deeper bite. It would be interesting to see just how effective they are. I've seen a number of ground anchors in use over the years and there's ground anchors and there's ground anchors if you know what I mean and even the best don't always give a good anchor point dependent upon conditions. Yes I to look forward to seeing a set at Lincomb, let the challenge begin
