wobbly
I started replacing the rear discs with the roughtrax replacements.
Started on the off side rear.
Wheel off.
Spacer off.
Caliper off.
Found that the two screws holding the disc in place have been sheared off, so drilled them out with a HSS bit.
The disc still wont come off, it will pull about just off the edge of the central hub, but absolutely no further.
The handbrake was off, but the only thing that can be holding it in situ is the handbrake pads?
Makes me think the osr handbrake is seized on, cos there is far more movement on the working parts behhind the nsr wheel.
Have I missed something - is there anything else holding the disc in place?
The manual doesnt suggest anything at all.....
Pete
Wheel off.
Spacer off.
Caliper off.
Pete
