Hi, I am trying to remove the vinyl in the rear of my 105 series and am having trouble.
Please tell me what this is in my attached pics. I can't remove it and the vinyl won't come out unless I do. Under neath the vinyl is a small thin metal plate which has 2 long screws each side of the main bolt. These screws and the main bolt tap into another small plate under the truck body.
Interestingly the metal arm rotates freely, and while it has a hole in it at the end, and one in the vinyl beneath, there is no anchor point for anything to screw into.
The plastic top of the main bolt spins freely, independent of the main bolt- it can not be removed...it seems...someone has obviously tried before me as well.
Any help would be much appreciated, thank you.
