REMY Brake Calipers
i have been doing the same so looked at lots of companies. the problem with those is they dont say that they 100% fit a late model 80. they only say the will fit a 4.2 1hz from 84-2010 which is not anymodel that you have. They are also stupidly cheap. have you rang them to see if they fit? make sure the company offer ones that fit from a 93on some companies i spoke to said that they are all the same but if they were why would i change them????
best i found some were around £80 each with a sercharge but i brought second hand ones and going to rebuild my self.
stu
Thanks Stu where did you get the caliper kits?
