- Mar 1, 2010
I craftily inserted a long rubber hose into the filler neck to syphon the petrol out but came up against an obstruction but persisted but corkscrewing it round and then it went in another foot or so. Then I syphoned the petrol out. Job done no. I could not pull the hose out and had visions of either taking out the fuel tank or cutting the hose off as low as possible to get the station nozzle in. Anyway I eventually corkscrewed it out.
Interestingly after that I undid the tank plug and only 3 Litres came out. Also the plug was loose but not leaking so I suggest everyone check theirs. There is a shoulder on the plug with a rubber washer to seal. I think it should be tightened until there is metal to metal contact with the rubber fully compressed.
The slightly polluted petrol is for my and my neighbours lawnmowers. And the only diesel strimmers in the country.
Frank
Frank
