I have recently acquired a Renault K9K 1.5dci. it's an early generation mode without common rail, but loaded with crankshaft, camshaft and a few other sensors, egr etc. I'm wondering if there is an inexpensive way to get it running without the original loom? I did a quick search for an simple aftermarket ECU but they are quite pricey for up-cycling old engines.
I did briefly consider some sort of a distributor type contraption on the bottom pulley to pulse the injectors but that's as far as I have got. Has anyone successfully done similar in getting an efi engine to run without a complete harness
