Graham
Hi All,
You may recall I was concerned about rust on the rear cross member of my daughters 100 series.
Well I gave Westcoast 4x4 a ring, and asked if I could come along with it, for a more knowledgeable opinion.
I duly took it along and met up again with Paul and his dad.
I said that my daughter has several horses, and would be asking them to fit a towbar, as she will tow a double horsebox with a pair of decent weight horses.
Paul had a look under the chassis, around the rear cross member, and said no problem there,
There is a bit of rust at the bottom of one of the rear doors.
Also there is rust on the underside of the top rear tailgate.
Paul said he is very busy at the moment, and to give a ring towards end of July, and he will fit it in, in August
Graham
Graham
