With no fuel boost alterations you'll probably get nothing. In fact you could even lose power as there'll be a slight lag in boost pressure build up across the IC. The whole point of fitting an IC is so you can increase fuelling and boost (which would normally take EGT's to dangerous levels) to gain more power and torque. Look at the on road performance figures for the 1HD-FT before and after conversion. You don't get improvements like that with a mere 5% power/torque increase. JMO
Any system that increases power at the expense of useability is bordering on pointless because if you are increasing EGT to dangerous levels you cannot use the extra power all the time.
Back in July 1990 Off Road and 4 Wheel Drive magazine tested a VX LC with the 4.2 turbo diesel. They timed a 0-60 mph sprint at 10.5 seconds. Nearly a decade later and now with an extra 30% power, a later version of the same motor takes 12.2 seconds to do 0-62 mph.
Something doesn't add up.
If the intercooler company had faith in their system, they would do a before and after power test on a dyno, preferably motor only on a test rig.
Claims, without a proper test procedure are spurious.
Also bare in mind that this motor had a 3" so called performance exhaust system fitted, which, according to Beaudesert Exhaust systems, is good for a power increase of 15-18% all on it's own.
When Toyota fitted an intercooler to the 1-KZTE engine, they did not claim an increase in torque or BHP, even though I would assume the fuelling had been modified to suit.
Back in 1939, the Messerschmitt ME 209 set a new air speed record of 469.22 mph. The DB 601 engine, normally rated at 1050 BHP was tuned to give 2,300 BHP for the two runs.
It had a life expectation of 30 minutes.
Fitting an intercooler will lower the charge temperature and improve the reliability of an engine by reducing the EGT. If you exploit that increase in charge density by boosting the turbo output and increasing fuelling, you may increase power but you will increase fuel consumption and lower reliability.
Roger
