Antipodes4WD
- May 12, 2024
My Landcruiser 2005 is close to 370,000km and I believe it was towing a caravan at some stage in its life. The clip seat at the end of the axle looks pretty worn out, but holds. Outer CV boot is leaking right from where it is attached to the hub.
I can buy new boots and go through the process of disassembly-assembly with a lot of grease in between, but I don't think I have competence to judge how worn out the CV joint are. Taken the mileage, would I be better served buying genuine replacement driveshafts?
