Garfieldus
- Nov 18, 2010
Monty, my 1997 24v manual is in for a new clutch at the moment . I decided to fit a Toyota Optifit.
I suspected the flywheel would need skimming as it was juddering at times. Just got a call from the mechanic. There are discoloured hot spots on the flywheel but his engineering shop is suggesting that skimming it will make it worse.
I called another very experienced engineer whose shop does this all the time and he says that he has never heard that skimming would cause problems.
Do you have any advice for me?
