Do i need a special primer if i want to re-paint the plastic front grill ??
Red Oktober Well-Known Member Joined Mar 27, 2011 Messages 1,364 Garage Country Flag May 29, 2011 #1 Do i need a special primer if i want to re-paint the plastic front grill ??
P Paul_Humphreys Well-Known Member Supporter Joined Mar 1, 2010 Messages 1,301 Country Flag May 29, 2011 #2 Yes, if you take it back to bare plastic. But if you just "flat" the paint then no. Paul
Red Oktober Well-Known Member Joined Mar 27, 2011 Messages 1,364 Garage Country Flag May 29, 2011 #3 great .... so i can just put a key into it with some wire wool then spray over it
J joinerman Well-Known Member Joined Mar 23, 2010 Messages 2,912 Garage May 29, 2011 #4 I did mine, With this, Been good for the last three years You don't need to use the acid etch primer.
Red Oktober Well-Known Member Joined Mar 27, 2011 Messages 1,364 Garage Country Flag May 29, 2011 #5 That's great ... cheers guys
Annamarie Well-Known Member Joined Mar 27, 2011 Messages 713 May 29, 2011 #6 joinerman said: I did mine, With this, Been good for the last three years You don't need to use the acid etch primer. Click to expand... but it didn't look like that in the beginning though did it we want to keep it shiney
