Paul
Well, as some know i recently fited a set of ST Maxx tyres to the truck.
When doing the pressures recently i noticed that there was a split in the bead of one tyre. On closer inspection i found the crack/split carried on nearly all the way around the rim. It could be a fitting error but the rest of the tyre is spotless, i have only done about 500-1000 road miles.
A quick look at the others and no other faults so i contacted Craddocks where i bought them and they said they would contact Coopers, i did give the little speach that i would be persuing this one very carefully and forcefully if needed. After chasing them over a period of two weeks i have an answer. Coopers will send me a new tyre directly and arrange collection of ther faulty one, there was a small discussion about fiting costs which i will chase later but i did say that i want to inspect every other tyre very carefully before i carry on in case of another failure. Did this while doing maintenance and found the other front tyre has a small but definate split.
I will contact them again tomorrow as i'm afraid i now have no confidence with this model, and who is to say that the tyres i get to replace them dont have the same fault as i would image with such a new tyre they would be from the same batch. I am going to chase for a full refund and choose something else.
Forgot to add, the pics are with the wheel off the truck, when on with a crack at the bottom it spreads open quite a bit.
