- Feb 2, 2013
While under the truck today i was thinking about how i would go about making a quick release for the bar when i realized my bar is probably messed up .
I had forgotten that i dropped the the brackets that hold the bar to the chassis shortly after i had a body lift so some time later i did what most do after fitting a +2" suspension lift and replaced the front drop links with rear links which are longer .
Now i'm thinking it should be longer links or lowered brackets not both but i am struggling to get my head around it .
What do you think ?
A : swap links for normal sized and leave bracket spacers in .
B : remove bracket spacers .
C : leave it as is .
90 series Landcruiser independent front suspension .
What do you think ?
