I'm thinking of swapping my current Cooper STTs for something else. The OEM size on the 120 is 265/65x17 which gives an overall diameter of 30.56". I'm currently running 265/70x17 which work out at 31.61". I'd like to go to 33" or better without causing massive extra stresses or problems, primarily to get more air between the sump guard and the ground.
So I was wondering if I should go wider, thus higher. A 285/70x17 will give me OD of 32.71" and 295/70x17 gives 33.26"
Wary of too much width though.
So stay same width as OEM and go taller? I was looking at 265/85x17 which gives 34.74" or 265/80x17 at 33.69"
Slightly narrower at 255 gives 33.06" and 34.07" at the two profiles.
What of these is the better alternative?? Does increasing diameter per se add stress to bearings like going wider does?
Anyone got any reputable brands that does a decent AT or MT in an 80 or 85 profile in 17"? They seem to be a but like rocking horse poep!!
