I'm getting close to wanting to replace the Cooper STTs as they're getting to the limit of doing anything useful in mud (read: I got stuck in a small mud-hole 2 weeks ago, and all the tread did was pack in the mud till I was running 4 slicks ...
So I've been doing a little research, and BFG now import the KM2 in my size - 265/70x17. This opens up the selection a little bit. I had wanted to go to 285/70x17, but my tyre calculator is only showing a 1.1" OD change - so, at the very best, I'll probably only get a maximum of 1/2" extra under the diff, for quite a bit more money, and the associated problems the extra width is going to give me - pretty sure the tyre will catch on the UCA and links on the inside. suspension and body lifts have sorted any rub on body trim and chassis / mudguards, so height is not an issue, but width will be.
I could fit new 17" rims with a better offset of say 12 or even 0 to pull the tyre away from the UCA etc., but that makes the package stupidly expensive (even though I do like the Mickey Thomson rims
Question 1 - do I go with 285/70x17 tyres, or stay with 265/70x17 tyres
Question 2 - do I go with another MT bias tyre (Maxxis Bighorn or Buckshot, BFG KM2, Cooper STT or ST Max or Hankook Dynapro MT) or do I go with an AT bias tyre (BFG AT, Cooper AT3, GG AT)
Question 3 - which brand / tyre to go with - they are all much of a muchness in price if you shop around carefully .... except for BFGs which have a bit of a premium in some places.
Tyre wear on the Cooper STTs I'm running now has not been great (only done about 22,000 miles and they're pretty shot) and the sidewalls have taken a battering in Wales and the Lakes, and I keep getting MOT advisories on them
although the're still mostly OK. So I'm not terribly keen on putting those back on. 90% of my driving is on-road, but Morocco and Western Sahara on the cards in the next year (or a similar destination) so a decent AT tyre at least is going to be needed for that trip.
Any thoughts / advice, folks? Ideally, I'd like to go with something like 265/75x17 which give almost the same OD as a 285/70x17 but without the extra width, which isn't really necessary, I think? But I can't find that profile at all
