That’s the same in any vehicle on any axle equipped with an axle locking diff, not just an 80.Just to clarify.....
When the rear diff on the 80 is locked the drive goes equaly to both wheels regardles if one is on glass and the other on tarmac.
The same applies to the front axle as well.
Dave
No, if you have locked the centre differential you only need one front and one rear to be spinning to be stuck, your just locking the front and rear together, not across the car. for both rears to be spinning you need a rear axle diffloc as well.I note the OP said he had drive to the rear and then asked if he should engage the centre diff, surely the centre diff has to be engaged to get the rear to lock?
In which case he would (should) have solid drive to both rear wheels and solid drive to one of the front wheels, i.e. the front wheel with least traction would be spinning.
Dave
Ah with you,I know how it all works, I was pointing out the rear diff lock does not engage unless the centre lock is engaged first. He said he had rear wheel drive, I assumed he meant he had engaged the rear diff lock, and I was then asking how he did that without engaging centre first?
Dave
Ah with you,
from the way it read it looked as though you were expecting the centre lock to also lock up the rear (a common misconception).
So it's getting close to mud season and I really need to nip off some time to sort out the 4WD.
I see in the manual there are various options of transfer case coupled to transmission according to the engine mounted.
I have tried to find the codes stamped on the casings but just can't find them. Where are they located on the transmission and transfer case?
The vehicle specs say there is a 442F transmission mounted. I need to know whether it is coupled to a full time 4WD transfer case, HF-2A, or a part time 4WD transfer case, HF-1A.
Engine is 12 valve 1HD-T.
So where to look to find the various markings for HF-2A or HF-1A on the transfer case?
Steve
Ah, the old diff discussion. Open diffs don't split power equally to both sides, and the fact that they redirect power to the side with the least traction is simply because they spit TORQUE in two EQUALS. In some cases this may make a difference in understanding what is happening.
With three open diffs, central front and rear and one rear wheel in the air, the torque to the rear wheel on the ground will be the same as to the one in the air, so very small, just the drag of the brakes. Hence there will also be a small torque to the rear output of the central differential and so also to its front output and that will end up as the same torque on both front wheels. You will notice it when you do the test, the car may want to move slightly when you spin the wheel in the air. If we have a front wheel in the air too, only the wheel with the least drag will spin as all others get the same torque and that is not enough to spin any of them.
