BobMurphy
- Mar 1, 2010
I recently put up a couple of pictures of my Ford Transit Cherry Picker against an 80ft dead Beech tree.
Pat put in a request . . . .
"Bob,Will you put more pics up when you do the job as it looks real challenging
Regards Pat"
This was the picture that had Steve reaching for the sick bag . .
Using the Cherry Picker and a hand-thrown line I managed to get a pair of 10 metre 2-ton strops looped over the upper branches.
I wasn't happy with the position of the left-hand one and changed it to loop around the main stem. My plan was to cut the right-hand one first as it was further from the outbuilding and the left-hand one would prevent it falling on me (and the building) if it all went belly-up.
I lifted the anchor chain up and shackled it to the strop. so far so good.
One for Steve .
The intention was to pull the RH fork towards a large Ash tree at the edge of the property on the far side of my wood pile.
Strops were set . . . .
And my cable winch was replaced by a proper 'Tirfor Winch' with a much longer pull.
It was looking good.
I started cutting a notch - without much tension on the chain as I didn't want to risk trapping the bar. That worked OK.
I tensioned the 'Tirfor' and started cutting the back of the trunk. It started to trap the bar so I went back down and gave the Tirfor everything, I could hear the tree starting to crack under the load.
Back up and continued cutting - the cut was opening up nicely and it looked as though it was going to fall where I wanted . . .
As it fell it twisted round and the off-set upper branches pulled it to the side. I guess there just wasn't enough weight in the doubled anchor chain to keep it moving. It fell to the side of a Lime tree, knocking off a couple of branches but it also caught the phone line - breaking the catenary cable that it hangs from. The phone line just hung a bit lower and the phones still worked. Ho Hum, I eventually cleared the site and re-hung the phone cable from the pole. Its a nice neat job, disguised with black Gaffer Tape but one day it will bite me when BT spot that its been repaired .
A few days later it was time to tackle the other half. This time I had arranged for the two 'lads' from the farm to bring the Merlo Telehandler into the field next to the garden. I had the chain all ready, plus a pair of PMR radios.
We got it all set up and I cut a large notch, then they pulled while I cut the back and it fell where I wanted it - right into another Lime tree!
The main trunk made a fair sized hole in the ground.
The top made a bit of a mess of the Lime Tree, but it will survive.
I then cut about six ft of the main trunk off, while everything was set up.
It made a large hole as well!
I now have about 20ft of main trunk still standing.
What caught me out with this tree is that it was much further 'gone' than I thought. It had some leaves last year so I thought it had just died and that the wood would still be flexible. It isn't, its quite dead and instead of folding neatly into the notch when cut it just snaps. That's why the first half fell the way it did.
I was thinking that the main trunk would be good for milling, but the chippings are very light and its quite soft - its just a large lump of firewood (3.2 metres circumference at the base).
This view may show the state of it. That lower cut is in good condition and the wood I've logged is really nice.
I'll drop the main trunk when I've cleared the fallen stuff and logged it.
I now have a 'Forest Master FM16' electric log splitter. Its supposedly equivalent to a 16-ton splitter because its got two splitting wedges on an 8-ton ram. Its quite impressive but it needs to be higher as crouching alongside it isn't good for the posture.
Unfortunately it weighs 78 kilos and is an awkward shape so I doubt I can lift it onto a table without help - which isn't usually available.
Its an impressive machine though. The other day it sheared one of the four bolts that holds one of the wedges - its a high-tensile M10 cap-head set !
First I have to get my Solo 662 24" saw running, its short of sparks and is now coming apart while I seek the cause. Its all solid state so what's to fix ?? I hope I can get parts.
My two 20" saws are a bit small for these logs .
I'll have to stop working on cars and get on with the logging before the cold weather arrives.
Bob.
Regards Pat"
One for Steve .
Bob.
