tyres/ lift / spacers Kzj70
lc27
gents.
I may change my standard wheels/tyres R15, for a set of wheel and tyres 285/75/R16 BF Goodrich that a friend is not using.
they are wider and taller than my R15, so I presume I will need to lift the car 2"? and perhaps put some spacers? if so what size
any recommendation?
do I need to consider anything else? since they seem to be more heavy as well.
also any recommendation where to buy the lift kit and spacer in the Uk will be appreciated.
thanks
M
I have 285s on a 2" lift with -50 offset wheels and zero rubbing, could probably get away with smaller offset, try raptor4x4, they sell lift kits, I had ironman on mine but eventually changed the rear spring and shocks all round as they sagged like fook
thanks for the help/ I presume is 50 mm offset. Any other changesdo I need to consider like a steering damper or so? Did you had to modify any of the brakes lines etc?
M
