Hello chaps,
Been a while since I've posted on here, I've been distracted with new hobbies that have taken over the Land Cruiser fiddling However, I do still have the Cruiser and still using and enjoying it.
I have a small (I hope) problem at the moment that I'd appreciate your help with, I've recently noticed a vibration that starts at approx. 30mph and then smooth's out with additional speed, the vibration is accompanied by a metallic rattling sound.
I though, aha, classic UJ symptoms, I've pulled the front prop and it's not really too bad, the front joint is fine, the rear has a very small tight spot, so I'll swap that one out, I haven't pulled the rear prop yet but driving the truck on just the rear prop with centre diff locked, I'm still getting the vibes and noise.
To cut to the chase, I've searched and read a few posts on Milner/Roughtrax UJ's, what's the general consensus, don't touch with a barge pole or ok (bearing in mind correct orientation of the grease nipple)?
Thanks!
Thanks!
