Ok guys, been out this a.m. and despite convincing myself otherwise, and proceeding to muddy the waters with light bulb positions, fittings etc, - probably looking at too many pictures of light options I think?, and a bit of senility creeping in, found I have exactly the same set up as DH.
Bulb holders are there, (sorry Karl for sending you off on a wild goose chase for those), bulb positions are exactly as Tony listed earlier, and as shown in photos by Karl and DH.
As per DH. I am just lacking the extra wires in connector block like Karl has, (somehow I remembered that bit right) and the extra terminal on the back of the centre lightfitting with the attached connecting wire I think, although the contact is there built in to the bulb holder.. There are no amber indicator bulbs in mine, but as they are not operational, not surprising.
DH as you have the bulbs, maybe someone tried and failed in the past to get yours working thinking a quick cheap fix, cos bulbs were missing originally?
Anyway, as you said before prob not too difficult to make something up, I have loads of old brass/ copper electrical bits in garage that might be cannibalised, amongst all the other 'junk' as 'er indoors describes it.
With Karl's photos of the 'real' thing, the correct colours for the extra wires are shown, so should be poss. to make up a small loom for each side in those colours, taking supply off towbar loom as discussed and shown earlier. I like using correct colours as had an uprated mini once that I wired loads of accessories up with all the same coloured yellow wire that I had a whole reel of the correct rating. When it later came to fault finding, I was well pizzed.
I looked at the possibility of buying cheap /used/broken light units as suggested, to rob parts off, but the cheapest I could find was £60 for one, so you know the answer to that.
Seems like progress here in parts/ knowledge from the think tank. Will now try to find/ assemble the few bits required for fully operational upper lights, from your collective information. Thanks Mates.
elf
