- Jan 30, 2019
where should i drill for the oil discharge on landcruiser 100 4.7
thanks
thanks
The sump?
They have a bolt you can undo. No drilling required
but where aboutsKano in the inlet manifold for valve saver as I run on lpg
Post up a picture of your engine with the intake manifold and pipework clearly visible and someone will be able to guide you. Essentially the picture shows it drilled and fitted where the manifold branches. I would also make sure no swarf goes into the manifold either by removing it or plugging it with paper and using a vacuum cleaner to suck it out depending on access.but where abouts
Any chance of a photo so I can see how you did itKano in the inlet manifold for valve saver as I run on lpg
