VSC TRAC & VSC OFF lights
shmelvin1
united_states
2003....I started the car this morning and the VSC TRAC & VSC OFF lights were on. I drove 10 minutes stopped for a while the started up again, the lights were still on, then drove about 100 miles home, no noticeable difference in performance. Got home shut it off then started it back up 10 minutes later and the lights are out....Any ideas?
Do they come back on when you drive though?
Probably need to get the codes read
Clear the codes, see what comes back then check each one. As one is moaning about voltage check your battery is ok and your alternator is putting out 14v+
